Ir para o conteúdo principal
IBM ThinkPad A30 Fan Replacement
O que você precisa
  1. IBM ThinkPad A30 Fan Replacement, Battery: passo 1, imagem 1 %32 IBM ThinkPad A30 Fan Replacement, Battery: passo 1, imagem 2 %32
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. IBM ThinkPad A30 Fan Replacement, Upper Case: passo 2, imagem 1 %32
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  3. IBM ThinkPad A30 Fan Replacement: passo 3, imagem 1 %32
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  4. IBM ThinkPad A30 Fan Replacement: passo 4, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 4, imagem 2 %32
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  5. IBM ThinkPad A30 Fan Replacement: passo 5, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 5, imagem 2 %32 IBM ThinkPad A30 Fan Replacement: passo 5, imagem 3 %32
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  6. IBM ThinkPad A30 Fan Replacement: passo 6, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 6, imagem 2 %32 IBM ThinkPad A30 Fan Replacement: passo 6, imagem 3 %32
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  7. IBM ThinkPad A30 Fan Replacement: passo 7, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 7, imagem 2 %32
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  8. IBM ThinkPad A30 Fan Replacement: passo 8, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 8, imagem 2 %32 IBM ThinkPad A30 Fan Replacement: passo 8, imagem 3 %32
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
  9. IBM ThinkPad A30 Fan Replacement, Display Assembly: passo 9, imagem 1 %32
    • Remove the 5.6mm screw that holds the LCD to the upper case.
  10. IBM ThinkPad A30 Fan Replacement: passo 10, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 10, imagem 2 %32 IBM ThinkPad A30 Fan Replacement: passo 10, imagem 3 %32
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
  11. IBM ThinkPad A30 Fan Replacement: passo 11, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 11, imagem 2 %32
    • Pull out the white tab connecting the LCD to the motherboard.
  12. IBM ThinkPad A30 Fan Replacement: passo 12, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 12, imagem 2 %32
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
  13. IBM ThinkPad A30 Fan Replacement: passo 13, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 13, imagem 2 %32 IBM ThinkPad A30 Fan Replacement: passo 13, imagem 3 %32
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
  14. IBM ThinkPad A30 Fan Replacement, Fan: passo 14, imagem 1 %32
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
  15. IBM ThinkPad A30 Fan Replacement: passo 15, imagem 1 %32
    • Lift the heatsink bracket up.
  16. IBM ThinkPad A30 Fan Replacement: passo 16, imagem 1 %32 IBM ThinkPad A30 Fan Replacement: passo 16, imagem 2 %32 IBM ThinkPad A30 Fan Replacement: passo 16, imagem 3 %32
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
Conclusão
Jessica
Membro desde: 10/06/10
162 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 4-44, Amido Fall 2010 Membro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membros
Autoria de 26 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 2,770
