Ir para o conteúdo principal
IBM ThinkPad 600E Hard Drive Disk Replacement
O que você precisa
  1. IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: passo 1, imagem 1 %32 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: passo 1, imagem 2 %32 IBM ThinkPad 600E Hard Drive Disk Replacement, Battery: passo 1, imagem 3 %32
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 2, imagem 1 %32
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 3, imagem 1 %32 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 3, imagem 2 %32 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 3, imagem 3 %32
    • Pry the battery out using your fingers.
  4. IBM ThinkPad 600E Hard Drive Disk Replacement, Hard Drive Disk: passo 4, imagem 1 %32
    • Put on the anti-static wrist trap and clip it to a large metal object.
    • If you do not have an anti-static wristband, make sure to touch a large metal object to ground yourself before beginning to work on your replacement. Occasionally touch the metal object.
  5. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 5, imagem 1 %32 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 5, imagem 2 %32 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 5, imagem 3 %32
    • Using a coin, remove the coin screw by turning counterclockwise.
    • It's best to use a thicker coin, such as a nickel.
  6. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 6, imagem 1 %32
    • Using a plastic spudger, pry off the plastic cover by pulling it out.
  7. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 7, imagem 1 %32 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 7, imagem 2 %32 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 7, imagem 3 %32
    • Utilizing your fingers, untuck the tab and pull to remove the hard drive.
  8. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 8, imagem 1 %32 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 8, imagem 2 %32 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 8, imagem 3 %32
    • Using a screwdriver, remove the screws by turning them counterclockwise to remove the bracket.
    • four 3mm PH0 screws
    • The metal bracket is still attached with a weak adhesive tape, gently pry it off with a spudger.
  9. IBM ThinkPad 600E Hard Drive Disk Replacement: passo 9, imagem 1 %32 IBM ThinkPad 600E Hard Drive Disk Replacement: passo 9, imagem 2 %32
    • The top plastic piece is adhered with a weak adhesive. Gently pry it off with a spudger.
Conclusão
3 outras pessoas executaram este guia.
Kevin Nguyen
Membro desde: 10/04/16
722 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-4, Nance Fall 2016 Membro de USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 58
Duração total: 3,142
