Ir para o conteúdo principal
IBM ThinkPad 600E Display Replacement
O que você precisa
  1. IBM ThinkPad 600E Display Replacement, Battery: passo 1, imagem 1 %32 IBM ThinkPad 600E Display Replacement, Battery: passo 1, imagem 2 %32 IBM ThinkPad 600E Display Replacement, Battery: passo 1, imagem 3 %32
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Display Replacement: passo 2, imagem 1 %32
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Display Replacement: passo 3, imagem 1 %32 IBM ThinkPad 600E Display Replacement: passo 3, imagem 2 %32 IBM ThinkPad 600E Display Replacement: passo 3, imagem 3 %32
    • Pry the battery out using your fingers.
  4. IBM ThinkPad 600E Display Replacement, Keyboard: passo 4, imagem 1 %32 IBM ThinkPad 600E Display Replacement, Keyboard: passo 4, imagem 2 %32 IBM ThinkPad 600E Display Replacement, Keyboard: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Use an antistatic wrist strap to avoid the risk of electric shock.
    • Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
    • It is easier to remove the coin screw using a thicker coin, such as a nickel.
  5. IBM ThinkPad 600E Display Replacement: passo 5, imagem 1 %32 IBM ThinkPad 600E Display Replacement: passo 5, imagem 2 %32 IBM ThinkPad 600E Display Replacement: passo 5, imagem 3 %32
    • Unlock the highlighted latch and pull the disk drive out.
    • Remove the disk drive.
  6. IBM ThinkPad 600E Display Replacement: passo 6, imagem 1 %32 IBM ThinkPad 600E Display Replacement: passo 6, imagem 2 %32 IBM ThinkPad 600E Display Replacement: passo 6, imagem 3 %32
    • Most of the screws have a small, plastic covering attached with an adhesive. Use the metal spudger to pry it off. Make sure to note which screw came from which hole.
    • Four 18mm long M2.5 screws
    • Two 16mm long M2.5 screws
    • One 4.5mm long M2.5 screws
    • Four 3mm long M2.5 screws
  7. IBM ThinkPad 600E Display Replacement: passo 7, imagem 1 %32 IBM ThinkPad 600E Display Replacement: passo 7, imagem 2 %32
    • Open the laptop all the way until it is flat.
    • Take the black circle off and remove the screw.
  8. IBM ThinkPad 600E Display Replacement: passo 8, imagem 1 %32 IBM ThinkPad 600E Display Replacement: passo 8, imagem 2 %32 IBM ThinkPad 600E Display Replacement: passo 8, imagem 3 %32
    • Pry the keyboard case up from the bottom and gently pry it up from all other edges.
    • Use caution when opening the case, as there are two ribbon cables attached to the keyboard case.
  9. IBM ThinkPad 600E Display Replacement: passo 9, imagem 1 %32 IBM ThinkPad 600E Display Replacement: passo 9, imagem 2 %32 IBM ThinkPad 600E Display Replacement: passo 9, imagem 3 %32
    • Pry the connectors of the ribbon cables off slowly, lifting straight up. Wiggle gently side to side if necessary.
  10. IBM ThinkPad 600E Display Replacement, Display: passo 10, imagem 1 %32 IBM ThinkPad 600E Display Replacement, Display: passo 10, imagem 2 %32
    • Remove the plastic part attached to the bottom of the screen.
    • Gently pull it from one side and then from another.
  11. IBM ThinkPad 600E Display Replacement: passo 11, imagem 1 %32
    • Remove the highlighted screws.
    • Five 4.8mm long M2.5 screws
  12. IBM ThinkPad 600E Display Replacement: passo 12, imagem 1 %32 IBM ThinkPad 600E Display Replacement: passo 12, imagem 2 %32 IBM ThinkPad 600E Display Replacement: passo 12, imagem 3 %32
  13. IBM ThinkPad 600E Display Replacement: passo 13, imagem 1 %32
    • Close the laptop and turn it around. There you will see 4 more screws.
    • Unscrew highlighted screws.
    • Four 4.8mm long M2.5 screws
  14. IBM ThinkPad 600E Display Replacement: passo 14, imagem 1 %32 IBM ThinkPad 600E Display Replacement: passo 14, imagem 2 %32
    • After you've removed the screws, open the laptop and gently pull the display out.
    • Be sure you hold it from the bottom edges while taking it out.
Conclusão
Uma outra pessoa concluiu este guia.
Kevin Nguyen
Membro desde: 10/04/16
722 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-4, Nance Fall 2016 Membro de USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 25
Duração total: 1,478
