Ir para o conteúdo principal
IBM ThinkPad 560z Keyboard Replacement
O que você precisa
  1. IBM ThinkPad 560z Keyboard Replacement, Upper Case: passo 1, imagem 1 %32
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  2. IBM ThinkPad 560z Keyboard Replacement: passo 2, imagem 1 %32 IBM ThinkPad 560z Keyboard Replacement: passo 2, imagem 2 %32
    • Open the flap on the left hand side.
  3. IBM ThinkPad 560z Keyboard Replacement: passo 3, imagem 1 %32 IBM ThinkPad 560z Keyboard Replacement: passo 3, imagem 2 %32
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  4. IBM ThinkPad 560z Keyboard Replacement: passo 4, imagem 1 %32 IBM ThinkPad 560z Keyboard Replacement: passo 4, imagem 2 %32
    • Open the flap on the right side.
  5. IBM ThinkPad 560z Keyboard Replacement: passo 5, imagem 1 %32
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  6. IBM ThinkPad 560z Keyboard Replacement: passo 6, imagem 1 %32 IBM ThinkPad 560z Keyboard Replacement: passo 6, imagem 2 %32
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  7. IBM ThinkPad 560z Keyboard Replacement: passo 7, imagem 1 %32
    • Use your fingers or a spudger to detach the connector.
  8. IBM ThinkPad 560z Keyboard Replacement: passo 8, imagem 1 %32 IBM ThinkPad 560z Keyboard Replacement: passo 8, imagem 2 %32
    • Carefully lift and remove the keyboard.
  9. IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: passo 9, imagem 1 %32 IBM ThinkPad 560z Keyboard Replacement, Keyboard Removal: passo 9, imagem 2 %32
    • Remove the five Phillips screws from the underside of the keyboard, then gently lift it up.
Conclusão
Derek Driscoll
Membro desde: 04/15/10
119 Reputação
8 Guias de autoria
Equipe
Cal Poly, Team 26-27, Regan Spring 2010 Membro de Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Membros
18 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 2,339
