Ir para o conteúdo principal
Hytera TC-580 Speaker Replacement
O que você precisa
  1. Hytera TC-580 Speaker Replacement, Battery: passo 1, imagem 1 %32 Hytera TC-580 Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Speaker Replacement: passo 2, imagem 1 %32 Hytera TC-580 Speaker Replacement: passo 2, imagem 2 %32
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Speaker Replacement, Antenna: passo 3, imagem 1 %32
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Speaker Replacement, Keypad: passo 4, imagem 1 %32
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Speaker Replacement: passo 5, imagem 1 %32
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Speaker Replacement: passo 6, imagem 1 %32
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Speaker Replacement: passo 7, imagem 1 %32
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Speaker Replacement: passo 8, imagem 1 %32 Hytera TC-580 Speaker Replacement: passo 8, imagem 2 %32
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Speaker Replacement: passo 9, imagem 1 %32
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Speaker Replacement: passo 10, imagem 1 %32
    • Peel off the keypad by hand.
  11. Hytera TC-580 Speaker Replacement, Speaker: passo 11, imagem 1 %32 Hytera TC-580 Speaker Replacement, Speaker: passo 11, imagem 2 %32 Hytera TC-580 Speaker Replacement, Speaker: passo 11, imagem 3 %32
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Speaker Replacement: passo 12, imagem 1 %32
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
Conclusão
Mohammed Chehab
Membro desde: 02/14/18
88 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S3-G4, Nance Spring 2018 Membro de USF Tampa, Team S3-G4, Nance Spring 2018
USFT-NANCE-S18S3G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 493
