Ir para o conteúdo principal
HyperX Stinger Ear Cup Replacement
O que você precisa
  1. HyperX Stinger Ear Cup Replacement, Ear Cup: passo 1, imagem 1 %32
    • Unplug your headset.
  2. HyperX Stinger Ear Cup Replacement: passo 2, imagem 1 %32
    • Firmly grip the old ear cup/cushion.
    • Pull the end of the ear cup foam until the bottom lip is released from the ear cup mount.
  3. HyperX Stinger Ear Cup Replacement: passo 3, imagem 1 %32 HyperX Stinger Ear Cup Replacement: passo 3, imagem 2 %32 HyperX Stinger Ear Cup Replacement: passo 3, imagem 3 %32
    • Slide the ear cup upwards to remove it.
    • Repeat steps 2 and 3 on the other ear cup.
  4. HyperX Stinger Ear Cup Replacement: passo 4, imagem 1 %32
    • Align the top lip of the replacement ear cup on the mount.
  5. HyperX Stinger Ear Cup Replacement: passo 5, imagem 1 %32 HyperX Stinger Ear Cup Replacement: passo 5, imagem 2 %32 HyperX Stinger Ear Cup Replacement: passo 5, imagem 3 %32
    • Pull the foam slowly over the mount.
    • Align the ear cup with the end of the mount, and then release, ensuring that the pad is securely attached to the mount.
    • Slowing down is necessary in this step to avoid over stretching the foam and damaging it.
  6. HyperX Stinger Ear Cup Replacement: passo 6, imagem 1 %32
    • Gently press the ear cups to the mount to make sure they are properly seated.
    • Repeat steps 4 through 6 for the other ear cup.
    • Test the headset to ensure the new ear cups are comfortable and secure.
Linha de Chegada
Philip Reyes
Membro desde: 09/14/23
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 143
