Ir para o conteúdo principal
HyperX QuadCast S Mute Sensor Replacement
  1. HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: passo 1, imagem 1 %32 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: passo 1, imagem 2 %32 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: passo 1, imagem 3 %32
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
    Pergunte ao FixBot
    Comentar
  2. HyperX QuadCast S Mute Sensor Replacement: passo 2, imagem 1 %32 HyperX QuadCast S Mute Sensor Replacement: passo 2, imagem 2 %32 HyperX QuadCast S Mute Sensor Replacement: passo 2, imagem 3 %32
    • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
    • Be careful not to damage the cable as you remove the top.
    • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
    Pergunte ao FixBot
    Comentar
  3. HyperX QuadCast S Mute Sensor Replacement: passo 3, imagem 1 %32 HyperX QuadCast S Mute Sensor Replacement: passo 3, imagem 2 %32 HyperX QuadCast S Mute Sensor Replacement: passo 3, imagem 3 %32
    • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
    • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
    Pergunte ao FixBot
    Comentar
Conclusão
Nathan Arruda
Membro desde: 10/25/22
765 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G1
5 Membros
Autoria de 9 guias
4Comentários do guia
Nice guide, but I've been unable to find a replacement.
Is the tap sensor from the Quadcast (the non-S version) compatible?
P S - Responder Compartilhar
I believe it should be compatible. The S version should just be different with its illumination and USB charging so the tap-to-mute sensor should be the same. Unfortunately, it's hard to source replacement parts since hyperx does not sell them separately. I could only recommend buying a used hyperx microphone for cheap and scraping the parts for replacement. Hope that helps.
Nathan Arruda - Responder Compartilhar
what is the cable order to put them back in. i have a yellow, red, white, and black cable
Jeremy Ray - Responder Compartilhar
Donde puedo comprar una remplazo de la Quadcast S TOUCH BOARD.V1 w45/19.hz?
Eladio Valencia Meneses - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 87
Ao todo: 5,515
