Ir para o conteúdo principal
Hyggly Percussive Massage Gun Battery Replacement
O que você precisa
  1. Hyggly Percussive Massage Gun Battery Replacement, Battery: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the 4 rubber stoppers on the massage gun.
    • You can use tweezers for ease or take the hard way and use your screwdriver.
  2. Hyggly Percussive Massage Gun Battery Replacement: passo 2, imagem 1 %32 Hyggly Percussive Massage Gun Battery Replacement: passo 2, imagem 2 %32
    • Using the Phillips #00 screwdriver, unscrew the 1 Phillips head screw underneath the power button.
    • Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws under the rubber stopper.
  3. Hyggly Percussive Massage Gun Battery Replacement: passo 3, imagem 1 %32 Hyggly Percussive Massage Gun Battery Replacement: passo 3, imagem 2 %32
    • Twist and remove the circular black lid that houses the main circuit board.
    • Pull apart the main body of the massage gun. The gun should now be in three parts.
    • Detach the wires connected to the main circuit board.
    • Remember to write down which wire attaches where.
  4. Hyggly Percussive Massage Gun Battery Replacement: passo 4, imagem 1 %32 Hyggly Percussive Massage Gun Battery Replacement: passo 4, imagem 2 %32
    • Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws inside the main body of the massage gun.
    • Pry open the lid once the screws are removed.
  5. Hyggly Percussive Massage Gun Battery Replacement: passo 5, imagem 1 %32 Hyggly Percussive Massage Gun Battery Replacement: passo 5, imagem 2 %32
    • Remove the top cover from battery compartment.
    • Remove the rubber sleeve off the battery compartment.
  6. Hyggly Percussive Massage Gun Battery Replacement: passo 6, imagem 1 %32 Hyggly Percussive Massage Gun Battery Replacement: passo 6, imagem 2 %32
    • Remove the sticker off the bottom of the battery compartment near the power switch.
    • Using the Phillips #00 screwdriver, unscrew the 3 Phillips head screws around the power switch to access the inside of the battery compartment.
  7. Hyggly Percussive Massage Gun Battery Replacement: passo 7, imagem 1 %32
    • Remove the bottom lid of the battery compartment to reveal the second circuit board.
    • Detach the wires of the battery from the circuit board.
    • Remember to write down the positioning of the wires.
  8. Hyggly Percussive Massage Gun Battery Replacement: passo 8, imagem 1 %32
    • Pry open the battery compartment
  9. Hyggly Percussive Massage Gun Battery Replacement: passo 9, imagem 1 %32 Hyggly Percussive Massage Gun Battery Replacement: passo 9, imagem 2 %32
    • Remove the old battery to replace the new one.
Conclusão
Raj Patel
Membro desde: 09/15/23
187 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 31
Últimos 30 dias: 107
Duração total: 1,160
