Ir para o conteúdo principal
Huffy Kids Tricycle Seat Replacement
O que você precisa
  1. Huffy Kids Tricycle Seat Replacement, Seat: passo 1, imagem 1 %32 Huffy Kids Tricycle Seat Replacement, Seat: passo 1, imagem 2 %32
    • Focus on the seat area for the replacement.
  2. Huffy Kids Tricycle Seat Replacement: passo 2, imagem 1 %32 Huffy Kids Tricycle Seat Replacement: passo 2, imagem 2 %32
    • Place the spanner on the bolt on the underside of the seat.
    • Then use a Phillips #2 screwdriver to remove the screw on the top of the seat.
  3. Huffy Kids Tricycle Seat Replacement: passo 3, imagem 1 %32 Huffy Kids Tricycle Seat Replacement: passo 3, imagem 2 %32 Huffy Kids Tricycle Seat Replacement: passo 3, imagem 3 %32
    • Repeat for the other screw.
  4. Huffy Kids Tricycle Seat Replacement: passo 4, imagem 1 %32 Huffy Kids Tricycle Seat Replacement: passo 4, imagem 2 %32 Huffy Kids Tricycle Seat Replacement: passo 4, imagem 3 %32
    • Lift the seat off of the trike frame.
  5. Huffy Kids Tricycle Seat Replacement: passo 5, imagem 1 %32 Huffy Kids Tricycle Seat Replacement: passo 5, imagem 2 %32 Huffy Kids Tricycle Seat Replacement: passo 5, imagem 3 %32
    • Place the new seat on the seat bracket, lining up the screw holes in the seat with the appropriate holes on the bracket.
    • Note that the bracket has two sets of holes for mounting the seat, so choose the appropriate set for the height of the rider. A taller rider will use the further set while a shorter rider will use the set closer to the handlebars.
    • Insert the screws from the top of the seat, using your spanner to hold the nuts under the screws.
  6. Huffy Kids Tricycle Seat Replacement: passo 6, imagem 1 %32 Huffy Kids Tricycle Seat Replacement: passo 6, imagem 2 %32
    • Give the seat a wiggle to check that it is tight against the bracket.
    • If there is any play, tighten the screws a few more turns.
Conclusão
To reassemble your device, follow these instructions in reverse order and you should be able to accomplish this
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 27
Duração total: 579
