Introdução
Huawei Y7 Prime 2018 LDN-TL10, LDN-L21, LDN-LX2
How to disassemble, screen with frame replacement
O que você precisa
Vídeo de Apresentação
Use Plastic tool to separate the back cover
With a Phillips screwdriver remove two black screws and the battery flex connector shield
Disconnect the battery and the finger print sensor flex cable
Remove all screws from the top of the logic board
Remove the shield covering the camera connectors
Remove the screws and the plastic cover at the bottom of the device
11 outras pessoas executaram este guia.
