Ir para o conteúdo principal
Huawei Y300 SIM Card Replacement
O que você precisa
  1. Huawei Y300 SIM Card Replacement, Rear Cover: passo 1, imagem 1 %32 Huawei Y300 SIM Card Replacement, Rear Cover: passo 1, imagem 2 %32 Huawei Y300 SIM Card Replacement, Rear Cover: passo 1, imagem 3 %32
    • Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone.
  2. Huawei Y300 SIM Card Replacement: passo 2, imagem 1 %32
    • Lift the battery with your finger up and out to remove the battery for replacement.
  3. Huawei Y300 SIM Card Replacement, Replace The Battery: passo 3, imagem 1 %32
    • After the battery is removed, replace the battery
    • Make sure the battery sits correctly by locating the power output at the bottom left.
  4. Huawei Y300 SIM Card Replacement, SIM Card: passo 4, imagem 1 %32
    • Remove the SIM card by sliding it upwards.
    • The gold plate on the SIM card should faced the back of the phone and the little dent sits at the bottom right.
    • Huawei Y300 will not accept micro SIM card.
Conclusão
5 outras pessoas executaram este guia.
Anthony Ng
Membro desde: 10/19/14
1.433 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G3
Membros da 4
Autoria de 8 guias
Um comentário
My Huawei Y300 doesn't read the Sim card when inserted. Why?
Evelyn - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 4,831
