Ir para o conteúdo principal
Huawei Y300 Motherboard Replacement
O que você precisa
  1. Huawei Y300 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Huawei Y300 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Huawei Y300 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Lift open the back cover
    • Disconnect the Battery
    • Disconnect the SIMcard
    • Remove the MicroSD card from its slot
  2. Huawei Y300 Motherboard Replacement: passo 2, imagem 1 %32 Huawei Y300 Motherboard Replacement: passo 2, imagem 2 %32 Huawei Y300 Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the 8 screws on the back and place them on the magnetic mat
  3. Huawei Y300 Motherboard Replacement: passo 3, imagem 1 %32 Huawei Y300 Motherboard Replacement: passo 3, imagem 2 %32 Huawei Y300 Motherboard Replacement: passo 3, imagem 3 %32
    • Pull of the back cover using the plastic opening tool
  4. Huawei Y300 Motherboard Replacement: passo 4, imagem 1 %32 Huawei Y300 Motherboard Replacement: passo 4, imagem 2 %32 Huawei Y300 Motherboard Replacement: passo 4, imagem 3 %32
    • Carefully detach the LCD and speaker ribbons from the Motherboard using the pliers
  5. Huawei Y300 Motherboard Replacement: passo 5, imagem 1 %32
    • replace the motherboard with a new one and re-attach the ribbon wires to the motherboard
Conclusão
30 outras pessoas executaram este guia.
murtaza
Membro desde: 10/16/14
748 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G3
Membros da 4
Autoria de 8 guias
5 comentários
So nice I am so lucky
sumon - Responder
To good and new I am so lucku
sumon - Responder
can i get schematic diagram review of this model plz i need it too much............thanx
DHAFER - Responder
plz help...where can in get a new huawei Y300 motherboard in nairobi kenya 0728499331
huwa - Responder
الهاتف إذا إتخبط مني يفصل
mahkma20 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 9,892
