Introdução
In this guide we are going to replace the LCD display on the Huawei ascend Y300 android smartphone. This may be necessary for a damaged screen causing lines, dark spots, and distorted images. The damage may be caused by:
- Physical impacts/pressure
- Heat
- Moisture
- Dust
Before we start it is a good idea to prepare an organized area and a bowl or tray to put the small screws in and prevent them getting lost to carry out the repair.
O que você precisa
Remove the rear cover at the back by pulling the gap located at the bottom of the phone.
Lift up and remove the battery.
44 outras pessoas executaram este guia.
2 comentários
good
it a good advise and easy
Its really helpful and so easy ... thanks
