Ir para o conteúdo principal
Huawei Watch 2 Battery Replacement
O que você precisa
  1. Huawei Watch 2 Battery Replacement, Huawei Watch 2 Opening Procedure: passo 1, imagem 1 %32
    • Before starting repairs, take your watch off the charger and power it down.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  2. Huawei Watch 2 Battery Replacement: passo 2, imagem 1 %32
    • Remove the four Torx T2 screws (4.5 mm length).
  3. Huawei Watch 2 Battery Replacement: passo 3, imagem 1 %32 Huawei Watch 2 Battery Replacement: passo 3, imagem 2 %32 Huawei Watch 2 Battery Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to remove the four plastic covers sitting next to the watch band holders.
  4. Huawei Watch 2 Battery Replacement: passo 4, imagem 1 %32 Huawei Watch 2 Battery Replacement: passo 4, imagem 2 %32 Huawei Watch 2 Battery Replacement: passo 4, imagem 3 %32
    • Insert an opening tool into the gap between the back cover and the watch case at the bottom edge of the back cover.
    • Use the opening tool to pry up the back cover of the Huawei Watch 2.
    • Do not remove the back cover assembly all the way yet—it's still connected to the mainboard.
  5. Huawei Watch 2 Battery Replacement: passo 5, imagem 1 %32 Huawei Watch 2 Battery Replacement: passo 5, imagem 2 %32
    • Carefully fold the back cover assembly to the opposite side of the two watch crowns.
  6. Huawei Watch 2 Battery Replacement, Huawei Watch 2 Battery Disconnect: passo 6, imagem 1 %32
    • Remove the Phillips #00 screw (1.8 mm length).
  7. Huawei Watch 2 Battery Replacement: passo 7, imagem 1 %32 Huawei Watch 2 Battery Replacement: passo 7, imagem 2 %32 Huawei Watch 2 Battery Replacement: passo 7, imagem 3 %32
    Comprar
    • The heart rate sensor flex cable is attached to the metal shield which covers the battery connector. In order to avoid damage to the flex cable, only grab the metal shield on the bottom end where the Phillips screw was located.
    • Use a pair of tweezers to carefully remove the metal shield.
    • Remove the back cover assembly.
  8. Huawei Watch 2 Battery Replacement: passo 8, imagem 1 %32 Huawei Watch 2 Battery Replacement: passo 8, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  9. Huawei Watch 2 Battery Replacement, Battery: passo 9, imagem 1 %32 Huawei Watch 2 Battery Replacement, Battery: passo 9, imagem 2 %32
    • In the following step you're going to pry out the battery.
    • In order to avoid damage to the flex cables running underneath the battery, only pry in the red marked areas.
  10. Huawei Watch 2 Battery Replacement: passo 10, imagem 1 %32
    • Apply a heated iOpener to the screen to loosen the adhesive which is holding the battery in place. Apply the iOpener for at least two minutes.
  11. Huawei Watch 2 Battery Replacement: passo 11, imagem 1 %32 Huawei Watch 2 Battery Replacement: passo 11, imagem 2 %32 Huawei Watch 2 Battery Replacement: passo 11, imagem 3 %32
    • Insert the flat end of a spudger between the bottom edge of the battery and the back cover.
    • Use the spudger to carefully pry the battery out of its recess.
  12. Huawei Watch 2 Battery Replacement: passo 12, imagem 1 %32 Huawei Watch 2 Battery Replacement: passo 12, imagem 2 %32
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
Conclusão
To reassemble your Huawei Watch 2 follow these instructions in reverse.
If possible, turn on your Huawei Watch 2 and test your repair before installing new adhesive underneath the battery and resealing.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
37 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
211.758 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.076 guias
16 comentários
Do you know what’s the model of the battery? My watch is starting to die really early (it says it’s at 77 but it then quickly drops to 0) and I need to replace it
NovaViper - Responder
Trickiest part is getting the heart rate sensor connector back in. There’s a little hook at the end opposite the screw hole that has to be slipped into place before laying the rest of it down. Took a few tries before it got seated. Whole thing took 10-15 mins start to finish.
Thomas Overton - Responder
I wish I had read this comment before following these instructions, this was the only step that was frustrating until i noticed the hook.
Richard Grove-White -
Like Richard, I found this the trickiest part of the job. I had not realised there was a very tiny hook and eventually positioned it accurately by luck rather than skill or judgement. I also had difficulty getting the battery connector seated properly and, again, it was by trial and error that I eventually got it attached correctly.
Alan Lambert -
before you begin make sure you have a t2 star screwdriver and hear a drier or something to heat up the battery from top so it will come off easier.
if you in usa you can get one from micro center called Mako Precision bit set it about 38$
but if you just want to do this job you can get from online for about 3$. and one prier flatspudger like the plastic one they sail here
and one tweezer. Without these tools, you cant complete job
eugene Talanov - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 51
Últimos 7 dias: 297
Últimos 30 dias: 1,130
Duração total: 58,700
