Ir para o conteúdo principal
Introdução
Use this guide if your Huawei Union’s speaker will not play sound while watching videos or listening to music.
  1. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
    • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
  2. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
    • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
  3. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  4. Remove the thirteen 3mm Phillips #00 screws from the back panel.
    • Remove the thirteen 3mm Phillips #00 screws from the back panel.
  5. Use the flat end of a spudger to pry off the back panel.
    • Use the flat end of a spudger to pry off the back panel.
  6. Use the flat end of a spudger to lift the speaker out of the frame and remove.
    • Use the flat end of a spudger to lift the speaker out of the frame and remove.
Conclusão
Brittany Achor
Membro desde: 14-02-2018
705 Reputation
6 Guias de autoria
USF Tampa, Team S1-G1, Nance Spring 2018 Membro de USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 Membros
6 Guias de autoria
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 68
