Introdução
Use this guide if your Huawei Union will not power on when the power button is pressed and you need to replace the screen.
  1. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
    • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
  2. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
    • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
  3. Remove the thirteen 3mm Phillips #00 screws from the back panel.
    • Remove the thirteen 3mm Phillips #00 screws from the back panel.
  4. Use the flat end of a spudger to pry off the back panel.
    • Use the flat end of a spudger to pry off the back panel.
  5. Remove a single 3mm Phillips #00 screw  from the motherboard.
    • Remove a single 3mm Phillips #00 screw from the motherboard.
  6. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  7. Using the flat end of a spudger to disconnect the motherboard ribbon cable. Using the flat end of a spudger to disconnect the motherboard ribbon cable.
    • Using the flat end of a spudger to disconnect the motherboard ribbon cable.
  8. Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
    • Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
  9. Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame. Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
    • Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
  10. Using an iOpener heat source tool, warm the screen of the phone to loosen adhesive of the screen.
    • Using an iOpener heat source tool, warm the screen of the phone to loosen adhesive of the screen.
  11. Wedge an opening pick underneath the screen and slowly work your way around the screen. Wedge an opening pick underneath the screen and slowly work your way around the screen.
    • Wedge an opening pick underneath the screen and slowly work your way around the screen.
  12. Using multiple Opening Picks, work your way around the edges making sure not to place too much pressure at any one point. With each pass, move the Opening Pick further to complete separation.
    • Using multiple Opening Picks, work your way around the edges making sure not to place too much pressure at any one point.
    • With each pass, move the Opening Pick further to complete separation.
  13. Once screen is sufficiently separated,  holding the sides of the frame firmly, use the Spudger to press through the  small access window to the screen at the top let and completely separate the screen from the frame. Do not push too firmly. Screen may break. If screen will not separate, use iOpener heating element again and start over. Do not press too far when separating the screen. There is a small ribbon cable attached to the screen that must be gently drawn through small access window.
    • Once screen is sufficiently separated, holding the sides of the frame firmly, use the Spudger to press through the small access window to the screen at the top let and completely separate the screen from the frame.
    • Do not push too firmly. Screen may break. If screen will not separate, use iOpener heating element again and start over.
    • Do not press too far when separating the screen. There is a small ribbon cable attached to the screen that must be gently drawn through small access window.
  14. Pull screen away from frame making sure the ribbon cable stays attached.
    • Pull screen away from frame making sure the ribbon cable stays attached.
Conclusão
Brittany Achor
Membro desde: 14-02-2018
705 Reputation
6 Guias de autoria
USF Tampa, Team S1-G1, Nance Spring 2018 Membro de USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 Membros
6 Guias de autoria
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 218
