Ir para o conteúdo principal
Introdução
Use this guide if your Huawei Union will not charge when plugged into a charger or begins losing charge faster than previously observed.
Peças
Nenhum componente especificado.
  1. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off. Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
    • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
  2. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  3. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out. Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
    • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
Conclusão
4 outras pessoas concluíram este guia.
Brittany Achor
Membro desde: 14-02-2018
705 Reputation
6 Guias de autoria
USF Tampa, Team S1-G1, Nance Spring 2018 Membro de USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 Membros
6 Guias de autoria
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 229
