Introdução
If your audio is muffled or distorted on your Huawei SnapTo G-620, then the speaker may need to be replaced. Use this guide to replace the speaker on your SnapTo.
O que você precisa
Remove the back cover.
Remove all fifteen 4mm Phillips J00 screws on the back panel.
Using a metal spudger or your fingernail, remove the back panel.
Quase terminado!
Conclusão
