Ir para o conteúdo principal
Huawei SnapTo G-620 Motherboard Replacement
O que você precisa
  1. Huawei SnapTo G-620 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Huawei SnapTo G-620 Motherboard Replacement, Battery: passo 1, imagem 2 %32 Huawei SnapTo G-620 Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
    • Remove all fifteen 4mm Phillips J00 screws on the back panel.
    • Using a metal spudger or your fingernail, remove the back panel.
  2. Huawei SnapTo G-620 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the pictured 4mm Phillips J00 screw.
  3. Huawei SnapTo G-620 Motherboard Replacement: passo 3, imagem 1 %32 Huawei SnapTo G-620 Motherboard Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to remove the pictured flat-top connector.
  4. Huawei SnapTo G-620 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the battery.
  5. Huawei SnapTo G-620 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Huawei SnapTo G-620 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Using the plastic opening tool remove the camera.
  6. Huawei SnapTo G-620 Motherboard Replacement: passo 6, imagem 1 %32 Huawei SnapTo G-620 Motherboard Replacement: passo 6, imagem 2 %32 Huawei SnapTo G-620 Motherboard Replacement: passo 6, imagem 3 %32
    • Use the plastic opening tools to remove all the remaining flat-top connectors
  7. Huawei SnapTo G-620 Motherboard Replacement: passo 7, imagem 1 %32 Huawei SnapTo G-620 Motherboard Replacement: passo 7, imagem 2 %32 Huawei SnapTo G-620 Motherboard Replacement: passo 7, imagem 3 %32
    • Using the spudger, pry open the zif connector, and remove the cable.
  8. Huawei SnapTo G-620 Motherboard Replacement: passo 8, imagem 1 %32
    • Using flat-side of spudger, remove the motherboard.
Conclusão
Equipe
USF Tampa, Team S2-G6, Nance Fall 2017 Membro de USF Tampa, Team S2-G6, Nance Fall 2017
USFT-NANCE-F17S2G6
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 30
Ao todo: 493
