Ir para o conteúdo principal
Huawei SnapTo G-620 Microphone Replacement
O que você precisa
  1. Huawei SnapTo G-620 Microphone Replacement, Battery: passo 1, imagem 1 %32 Huawei SnapTo G-620 Microphone Replacement, Battery: passo 1, imagem 2 %32 Huawei SnapTo G-620 Microphone Replacement, Battery: passo 1, imagem 3 %32
    • Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
    • Remove all fifteen 4mm Phillips J00 screws on the back panel.
    • Using a metal spudger or your fingernail, remove the back panel.
  2. Huawei SnapTo G-620 Microphone Replacement: passo 2, imagem 1 %32
    • Remove the pictured 4mm Phillips J00 screw.
  3. Huawei SnapTo G-620 Microphone Replacement: passo 3, imagem 1 %32 Huawei SnapTo G-620 Microphone Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to remove the pictured flat-top connector.
  4. Huawei SnapTo G-620 Microphone Replacement: passo 4, imagem 1 %32
    • Remove the battery.
  5. Huawei SnapTo G-620 Microphone Replacement, Microphone: passo 5, imagem 1 %32 Huawei SnapTo G-620 Microphone Replacement, Microphone: passo 5, imagem 2 %32
    • Using the plastic opening tool remove the camera.
  6. Huawei SnapTo G-620 Microphone Replacement: passo 6, imagem 1 %32 Huawei SnapTo G-620 Microphone Replacement: passo 6, imagem 2 %32 Huawei SnapTo G-620 Microphone Replacement: passo 6, imagem 3 %32
    • Use the plastic opening tool to remove all the remaining flat-top connectors.
  7. Huawei SnapTo G-620 Microphone Replacement: passo 7, imagem 1 %32 Huawei SnapTo G-620 Microphone Replacement: passo 7, imagem 2 %32 Huawei SnapTo G-620 Microphone Replacement: passo 7, imagem 3 %32
    • Using the spudger, pry open the zif connector, and remove the cable.
  8. Huawei SnapTo G-620 Microphone Replacement: passo 8, imagem 1 %32 Huawei SnapTo G-620 Microphone Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers or the spudger, remove the microphone.
Conclusão
Coleson Perry
Membro desde: 09/28/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S2-G6, Nance Fall 2017 Membro de USF Tampa, Team S2-G6, Nance Fall 2017
USFT-NANCE-F17S2G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 236
