Ir para o conteúdo principal
Huawei P9 Lite Motherboard Shield Removal
O que você precisa
  1. Huawei P9 Lite Motherboard Shield Removal, Back Cover: passo 1, imagem 1 %32 Huawei P9 Lite Motherboard Shield Removal, Back Cover: passo 1, imagem 2 %32
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Motherboard Shield Removal: passo 2, imagem 1 %32
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Motherboard Shield Removal: passo 3, imagem 1 %32
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Motherboard Shield Removal, Motherboard Shield: passo 4, imagem 1 %32
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  5. Huawei P9 Lite Motherboard Shield Removal: passo 5, imagem 1 %32 Huawei P9 Lite Motherboard Shield Removal: passo 5, imagem 2 %32
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
Conclusão
6 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
117.296 Reputação
Autoria de 188 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.521 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 5,951
