Introdução
Use this guide to remove the motherboard shield carrying the fingerprint sensor in your Huawei P9 Lite.
O que você precisa
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Remove the nine Phillips #00 screws that secure the metal shield plate.
6 outras pessoas executaram este guia.
