Ir para o conteúdo principal
Huawei P9 Lite Loudspeaker Replacement
O que você precisa
  1. Huawei P9 Lite Loudspeaker Replacement, Back Cover: passo 1, imagem 1 %32 Huawei P9 Lite Loudspeaker Replacement, Back Cover: passo 1, imagem 2 %32
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Loudspeaker Replacement: passo 2, imagem 1 %32
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Loudspeaker Replacement: passo 3, imagem 1 %32
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: passo 4, imagem 1 %32 Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: passo 4, imagem 2 %32 Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: passo 4, imagem 3 %32
    • On the bottom of the phone remove the following screws:
    • Three 2.9 mm Phillips #00 screws
    • Four 3.8 mm Phillips #00 screws
    • Now you can grab the loudspeaker unit and take it out.
Conclusão
12 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
119.222 Reputação
Autoria de 189 guias
Equipe
3 comentários
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
dtotisitswe - Responder
Same problem here. Any help?
fabio9999 -
Sir hy how are you. Sir p9lite song speaker not working.
Sufyan Raja - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 10,251
