Ir para o conteúdo principal
Huawei P9 Lite Headphone Jack Replacement
O que você precisa
  1. Huawei P9 Lite Headphone Jack Replacement, Back Cover: passo 1, imagem 1 %32 Huawei P9 Lite Headphone Jack Replacement, Back Cover: passo 1, imagem 2 %32
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Headphone Jack Replacement: passo 2, imagem 1 %32
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Headphone Jack Replacement: passo 3, imagem 1 %32
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Headphone Jack Replacement, Motherboard Shield: passo 4, imagem 1 %32
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  5. Huawei P9 Lite Headphone Jack Replacement: passo 5, imagem 1 %32 Huawei P9 Lite Headphone Jack Replacement: passo 5, imagem 2 %32
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
  6. Huawei P9 Lite Headphone Jack Replacement, Headphone Jack: passo 6, imagem 1 %32 Huawei P9 Lite Headphone Jack Replacement, Headphone Jack: passo 6, imagem 2 %32
    • Disconnect the headphone jack with a spudger.
    • Take the headphone jack out of its recess.
Conclusão
8 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
203.362 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
Um comentário
After replacing my audio jack only one side work using headphones
jan call me - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 6,850
