Ir para o conteúdo principal
Huawei P9 Headphone Jack Replacement
O que você precisa
  1. Huawei P9 Headphone Jack Replacement, Back Cover: passo 1, imagem 1 %32 Huawei P9 Headphone Jack Replacement, Back Cover: passo 1, imagem 2 %32 Huawei P9 Headphone Jack Replacement, Back Cover: passo 1, imagem 3 %32
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Headphone Jack Replacement: passo 2, imagem 1 %32 Huawei P9 Headphone Jack Replacement: passo 2, imagem 2 %32
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Headphone Jack Replacement, Fingerprint sensor: passo 3, imagem 1 %32 Huawei P9 Headphone Jack Replacement, Fingerprint sensor: passo 3, imagem 2 %32
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Headphone Jack Replacement, Headphone Jack: passo 4, imagem 1 %32 Huawei P9 Headphone Jack Replacement, Headphone Jack: passo 4, imagem 2 %32 Huawei P9 Headphone Jack Replacement, Headphone Jack: passo 4, imagem 3 %32
    • Remove the water indicator on top of the screw.
    • Undo the two Phillips #00 screws.
    • Remove metal bracket (mind the adhesive underneath).
  5. Huawei P9 Headphone Jack Replacement: passo 5, imagem 1 %32 Huawei P9 Headphone Jack Replacement: passo 5, imagem 2 %32
    • Disconnect the flex cable and remove the headphone jack.
    • The old headphone jack is equipped with a rubber seal, which holds the jack down to the phone. Take it off and put it on the new headphone jack.
Conclusão
3 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
117.802 Reputação
Autoria de 188 guias
Equipe
Um comentário
questo procedimento funziona anche con il modello p9 plus? grazie per l’attenzione
abcde181 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 5,934
