Introdução
Use this guide to replace the headphone jack in your Huawei P9 smartphone.
O que você precisa
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Remove the water indicator on top of the screw.
Undo the two Phillips #00 screws.
Remove metal bracket (mind the adhesive underneath).
3 outras pessoas executaram este guia.
