Ir para o conteúdo principal
Huawei P9 Front Facing Camera Replacement
O que você precisa
  1. Huawei P9 Front Facing Camera Replacement, Back Cover: passo 1, imagem 1 %32 Huawei P9 Front Facing Camera Replacement, Back Cover: passo 1, imagem 2 %32 Huawei P9 Front Facing Camera Replacement, Back Cover: passo 1, imagem 3 %32
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Front Facing Camera Replacement: passo 2, imagem 1 %32 Huawei P9 Front Facing Camera Replacement: passo 2, imagem 2 %32
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: passo 3, imagem 1 %32 Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: passo 3, imagem 2 %32
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 1 %32 Huawei P9 Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 2 %32 Huawei P9 Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 3 %32
    • Peel off the conducting fabric.
    • You will have to transfer it to the new camera (careful it's sticky).
    • Unplug the camera connector.
    • Now you can remove the front camera.
Conclusão
Uma outra pessoa concluiu este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
228.969 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 1,686
