Ir para o conteúdo principal
Huawei P9 Earpiece Speaker Replacement
O que você precisa
  1. Huawei P9 Earpiece Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Huawei P9 Earpiece Speaker Replacement, Back Cover: passo 1, imagem 2 %32 Huawei P9 Earpiece Speaker Replacement, Back Cover: passo 1, imagem 3 %32
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Earpiece Speaker Replacement: passo 2, imagem 1 %32 Huawei P9 Earpiece Speaker Replacement: passo 2, imagem 2 %32
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Earpiece Speaker Replacement, Fingerprint sensor: passo 3, imagem 1 %32 Huawei P9 Earpiece Speaker Replacement, Fingerprint sensor: passo 3, imagem 2 %32
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: passo 4, imagem 1 %32 Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: passo 4, imagem 2 %32 Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: passo 4, imagem 3 %32
    • Loosen the seven Phillips #00 screws on the motherboard.
    • On one of them might be a sticker. Remove it.
    • Unplug the antenna cable.
    • The metal plate covering the battery connector has two little hooks on each side. Use a tweezer to free them and unhinge the plate towards the top.
  5. Huawei P9 Earpiece Speaker Replacement: passo 5, imagem 1 %32 Huawei P9 Earpiece Speaker Replacement: passo 5, imagem 2 %32
    • Disconnect the volume button cable and the display cable …
  6. Huawei P9 Earpiece Speaker Replacement: passo 6, imagem 1 %32 Huawei P9 Earpiece Speaker Replacement: passo 6, imagem 2 %32
    • … as well as the battery connector and the cable running to the daughter board.
  7. Huawei P9 Earpiece Speaker Replacement: passo 7, imagem 1 %32 Huawei P9 Earpiece Speaker Replacement: passo 7, imagem 2 %32
    • Now you can lift out the motherboard to access the earpiece speaker.
    • Be careful with both cameras since they are still connected to the motherboard.
    • The earpiece speaker ist fixed with an adhesive foam gasket.
Conclusão
Dominik Schnabelrauch
Membro desde: 11/23/16
235.122 Reputação
Autoria de 682 guias
Equipe
iFixit EU Team Membro de iFixit EU Team
Staff
38 Membros
Autoria de 1.164 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 2,556
