Ir para o conteúdo principal
Huawei P9 Charging Board Replacement
O que você precisa
  1. Huawei P9 Charging Board Replacement, Back Cover: passo 1, imagem 1 %32 Huawei P9 Charging Board Replacement, Back Cover: passo 1, imagem 2 %32 Huawei P9 Charging Board Replacement, Back Cover: passo 1, imagem 3 %32
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Charging Board Replacement: passo 2, imagem 1 %32 Huawei P9 Charging Board Replacement: passo 2, imagem 2 %32
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Charging Board Replacement, Fingerprint sensor: passo 3, imagem 1 %32 Huawei P9 Charging Board Replacement, Fingerprint sensor: passo 3, imagem 2 %32
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Charging Board Replacement, lower section: passo 4, imagem 1 %32 Huawei P9 Charging Board Replacement, lower section: passo 4, imagem 2 %32 Huawei P9 Charging Board Replacement, lower section: passo 4, imagem 3 %32
    • Undo the three Phillips #00 screws.
    • Disconnect the loudspeaker flex connector.
    • Carefully remove the metal bracket.
    • Mind the adhesive underneath that might stick to the headphone connector.
  5. Huawei P9 Charging Board Replacement: passo 5, imagem 1 %32 Huawei P9 Charging Board Replacement: passo 5, imagem 2 %32 Huawei P9 Charging Board Replacement: passo 5, imagem 3 %32
    • Disconnect the motherboard flex cable and the antenna cable.
    • Unplug the headphone jack connector.
  6. Huawei P9 Charging Board Replacement, Charging Board: passo 6, imagem 1 %32
    • Now you can easily remove the charging board.
Conclusão
8 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
231.648 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.763 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 81
Ao todo: 7,378
