Introdução
Use this guide to replace the charging board in your Huawei P9 smartphone.
O que você precisa
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Undo the three Phillips #00 screws.
Disconnect the loudspeaker flex connector.
Carefully remove the metal bracket.
8 outras pessoas executaram este guia.
