Ir para o conteúdo principal
Huawei P9 Back Cover
O que você precisa
  1. Huawei P9 Back Cover, Back Cover: passo 1, imagem 1 %32 Huawei P9 Back Cover, Back Cover: passo 1, imagem 2 %32 Huawei P9 Back Cover, Back Cover: passo 1, imagem 3 %32
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Back Cover: passo 2, imagem 1 %32 Huawei P9 Back Cover: passo 2, imagem 2 %32
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Back Cover, Fingerprint sensor: passo 3, imagem 1 %32 Huawei P9 Back Cover, Fingerprint sensor: passo 3, imagem 2 %32
    • Disconnect the fingerprint sensor using a spudger.
Conclusão
8 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
132.901 Reputação
Autoria de 189 guias
Equipe
1Comentário do guia
I cant open the phone
Chizu - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 35
Últimos 30 dias: 98
Ao todo: 9,997
