Ir para o conteúdo principal
Huawei P8 Lite Motherboard Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Huawei P8 Lite Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Huawei P8 Lite Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Motherboard Replacement: passo 2, imagem 1 %32 Huawei P8 Lite Motherboard Replacement: passo 2, imagem 2 %32 Huawei P8 Lite Motherboard Replacement: passo 2, imagem 3 %32
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Motherboard Replacement, Loudspeaker: passo 3, imagem 1 %32
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Continue by removing the SIM and SD card trays on the side of the device.
  7. Huawei P8 Lite Motherboard Replacement: passo 7, imagem 1 %32 Huawei P8 Lite Motherboard Replacement: passo 7, imagem 2 %32 Huawei P8 Lite Motherboard Replacement: passo 7, imagem 3 %32
    • Remove the two Torx T5 screws. One may be cover with a liquid indicator.
    • Remove the five Phillips #000 screws.
    • Take away both securing brackets covering the motherboard.
    • If your phone has an NFC antenna, taking away the cover will automatically free its flex connector from the motherboard.
  8. Huawei P8 Lite Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the three Phillips #000 screws on the silver panel.
  9. Huawei P8 Lite Motherboard Replacement: passo 9, imagem 1 %32 Huawei P8 Lite Motherboard Replacement: passo 9, imagem 2 %32
    • Carefully separate the four connectors holding the motherboard in place.
    • Remove the motherboard from the device.
Conclusão
6 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-1, Kass Spring 2017 Membro de USF Tampa, Team 1-1, Kass Spring 2017
USFT-KASS-S17S1G1
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,106
