Introdução
This guide shows you how to replace the motherboard of your Huawei P8 Lite.
O que você precisa
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the three Phillips #00 screws that hold the metal plate in place.
Remove the metal plate with a tweezer.
Unplug the battery flex connector with a spudger.
To reassemble your device, follow these instructions in reverse order and apply adhesive where necessary.
9 outras pessoas executaram este guia.
Um comentário
My p8 lite is not connecting to mobile networks unless im in town onyl whats the prob
