Introdução
This guide will explain how to remove and replace the Loudspeaker for the Huawei P8 Lite.
O que você precisa
Ferramenta utilizada neste passo:Spudger$2.99
Begin by removing the back cover of the device with the Spudger. To prevent damage to the back cover, begin removing the cover half an inch to the right of the headphone jack and continue prying around the perimeter of the device.
Ferramenta utilizada neste passo:T5 Torx Screwdriver$9.99
Locate the Loudspeaker at the bottom of the device.
Remove the four black screws using the T5 Torx Screwdriver.
Then use the Phillips #000 Screwdriver to remove the three silver screws.
