Introdução
This guide will explain how to replace the Earpiece Speaker for the Huawei P8 Lite.
Ferramentas
Peças
Nenhum componente especificado.
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Continue by removing the SIM and SD card trays on the side of the device.
Using the Tweezers, carefully remove the Earpiece Speaker.
Insert the new Earpiece Speaker and follow these steps in reverse order to reassemble the device.
