Ir para o conteúdo principal
Huawei P8 Lite Earpiece Speaker Replacement
O que você precisa
  1. Huawei P8 Lite Earpiece Speaker Replacement, Remove  Back Cover and Loudspeaker: passo 1, imagem 1 %32 Huawei P8 Lite Earpiece Speaker Replacement, Remove  Back Cover and Loudspeaker: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Spudger
    $2.99
    • Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
    • Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
  2. Huawei P8 Lite Earpiece Speaker Replacement: passo 2, imagem 1 %32
    • Remove three silver Phillips 000 screws.
    • Remove four T5 Torx screws.
  3. Huawei P8 Lite Earpiece Speaker Replacement: passo 3, imagem 1 %32 Huawei P8 Lite Earpiece Speaker Replacement: passo 3, imagem 2 %32
    Spudger
    $2.99
    • Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
  4. Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: passo 4, imagem 1 %32 Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: passo 4, imagem 2 %32
    • Use the tweezers to grip the earpiece speaker and lift the earpiece speaker from phone.
Conclusão
To reassemble your device, follow Teardown Guide steps 12, 6, 5, 4, 3, 2, 1 in that order.
Brayden Mann
Membro desde: 02/05/16
645 Reputação
Autoria de 4 guias
Equipe
Metro State, Team 1-2, Carpenter Spring 2016 Membro de Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 2,208
