Ir para o conteúdo principal
Huawei P8 Display Replacement
O que você precisa
  1. Huawei P8 Display Replacement, Display: passo 1, imagem 1 %32 Huawei P8 Display Replacement, Display: passo 1, imagem 2 %32
    • First switch off your phone.
    • Remove the trays for the SD card and the SIM card.
  2. Huawei P8 Display Replacement: passo 2, imagem 1 %32
    • Remove the two Torx T2 screws located at the bottom next to the micro USB port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  3. Huawei P8 Display Replacement: passo 3, imagem 1 %32 Huawei P8 Display Replacement: passo 3, imagem 2 %32
    • Use an iSclack or a suction handle to separate the display unit from the rear panel.
  4. Huawei P8 Display Replacement: passo 4, imagem 1 %32
    • Remove the two Phillips #00 that hold down the two metal clamps covering the front camera, the display and battery flex connectors.
  5. Huawei P8 Display Replacement: passo 5, imagem 1 %32 Huawei P8 Display Replacement: passo 5, imagem 2 %32 Huawei P8 Display Replacement: passo 5, imagem 3 %32
    • Use a tweezer to remove the metal clamp covering the display and the battery flex connector.
    • Unplug the battery flex connector with a Spudger.
    • Remove the metal clamp covering the flex connector of the front camera.
  6. Huawei P8 Display Replacement: passo 6, imagem 1 %32 Huawei P8 Display Replacement: passo 6, imagem 2 %32 Huawei P8 Display Replacement: passo 6, imagem 3 %32
    • Unplug the headphone jack and the front camera flex connectors.
    • Remove the front camera.
  7. Huawei P8 Display Replacement: passo 7, imagem 1 %32 Huawei P8 Display Replacement: passo 7, imagem 2 %32 Huawei P8 Display Replacement: passo 7, imagem 3 %32
    • Unscrew the four Phillips #00 screws that hold down the motherboard of your Huawei P8.
    • Unplug the vibration motor flex connector.
    • Disconnect the antenna cable.
  8. Huawei P8 Display Replacement: passo 8, imagem 1 %32 Huawei P8 Display Replacement: passo 8, imagem 2 %32 Huawei P8 Display Replacement: passo 8, imagem 3 %32
    • Unplug the display flex connector from the main board with a Spudger.
    • Disconnect and remove the antenna cable with a tweezer.
  9. Huawei P8 Display Replacement: passo 9, imagem 1 %32 Huawei P8 Display Replacement: passo 9, imagem 2 %32
    • Use a spudger to disconnect the flex cable of the power and volume buttons.
    • Remove the liquid contact indicator that sits on top of the last screw holding down your main board.
  10. Huawei P8 Display Replacement: passo 10, imagem 1 %32 Huawei P8 Display Replacement: passo 10, imagem 2 %32
    • Unscrew the Phillips #00 screw.
    • Lift up the main board with a spudger and remove it.
  11. Huawei P8 Display Replacement: passo 11, imagem 1 %32 Huawei P8 Display Replacement: passo 11, imagem 2 %32 Huawei P8 Display Replacement: passo 11, imagem 3 %32
    • Remove the adhesive tape which is covering the display flex cable.
    • Loosen the adhesive around the mid frame with an iOpener.
    • In particular take care of the adhesive under the top and bottom of the display.
    • When the glue is softened you can use a spudger to get behind the display through the camera bay and get between the frame and the display.
  12. Huawei P8 Display Replacement: passo 12, imagem 1 %32 Huawei P8 Display Replacement: passo 12, imagem 2 %32 Huawei P8 Display Replacement: passo 12, imagem 3 %32
    • Insert an opening pick in the gap where you separated the display from the mid frame.
    • Insert just the tip of the opening pick and slide it along the right side to separate the display from the frame.
  13. Huawei P8 Display Replacement: passo 13, imagem 1 %32 Huawei P8 Display Replacement: passo 13, imagem 2 %32
    • Insert another opening pick at the top of the phone and loosen the adhesive under the upper part of the display.
  14. Huawei P8 Display Replacement: passo 14, imagem 1 %32 Huawei P8 Display Replacement: passo 14, imagem 2 %32 Huawei P8 Display Replacement: passo 14, imagem 3 %32
    • Insert just the tip of the opening pick and slide it along the left side of the phone to separate the display from the frame.
  15. Huawei P8 Display Replacement: passo 15, imagem 1 %32 Huawei P8 Display Replacement: passo 15, imagem 2 %32
    • Loosen the adhesive under the bottom part of the display unit with the opening pick.
    • Flip the opening pick a little to separate the display from the mid frame.
    • If you notice that there is still some adhesive which isn't loosened, use the iOpener to loosen it and slide once more along the mid frame with an opening pick.
  16. Huawei P8 Display Replacement: passo 16, imagem 1 %32 Huawei P8 Display Replacement: passo 16, imagem 2 %32
    • Lift up the display and remove it.
    • The display flex cable should easily go through the recess in the mid frame while removing the display.
Conclusão
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
10 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
257.365 Reputação
Autoria de 682 guias
Equipe
iFixit EU Team Membro de iFixit EU Team
Staff
37 Membros
Autoria de 1.226 guias
2Comentários do guia
Is there any difference on screen frame between GRA-L09 and GRA-TL10??? The l09 is the single sim and the TL10 is the dual sim…
Rafail Petridis - Responder Compartilhar
installing a new screen the first time, i was looking at darkness. then, taking it apart again and taking away the protective foil on the back of the screen, it just showed pink/purple colors and started heating up pretty bad around the charging connector. my idea would be a short circuit. any idea what is going wrong and can this still be saved?
Albert Einbein - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 24
Últimos 30 dias: 100
Ao todo: 18,620
