Introdução
prereq daughterboard replacement
O que você precisa
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the cover and the frame.
Insert an opening pick into the gap.
If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
Slide the opening pick to the bottom right corner.
If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
Insert a fourth opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Use a pair of tweezers to peel the black tape next to the rear camera off the motherboard cover.
Use a spudger to pry up and disconnect the power and volume button flex connector.
Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Start to slide a plastic card under the bottom right corner of the battery to cut the adhesive.
Slide the plastic card along the right side of the battery to further release the adhesive. Gently start to pry up the battery while doing so.
