Ir para o conteúdo principal
Huawei P20 Camera Lens Replacement
O que você precisa
    • If you have any questions, feel free to ask them!
Conclusão
5 outras pessoas executaram este guia.
Pieter
Membro desde: 11/10/15
494 Reputação
Autoria de 1 guia
5 comentários
Thanks, you helpt me well with this one!
Kristof Ven - Responder
Did this step by step, making sure not to touch the lense. Although, quality of photos are worse than before for some reason
Cole VHelm - Responder
Maybe the new lens is of a lower quality?
Pieter -
My lens hasn't broken it just has a smudge on the inside, can you do this and then use the same glue to put the lens back on. Or do you still recommend replacing the entire lens?
Luke Hardy - Responder
Hi Luke, Sorry for the late response. I had not seen your reply. It’s definitely going to be hard if you want to remove the glass in one piece.
Please let us know if it worked out for you. Good luck
Pieter -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 10,103
