Introdução
Use this guide to disconnect the battery in your Huawei P10 smartphone.
O que você precisa
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Remove the Phillips #00 screw.
Use tweezers to remove the metal plate.
Use a spudger to disconnect the battery flex cable.
Quase terminado!
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where it is necessary.
Conclusão
