Ir para o conteúdo principal
Huawei P10 Main and display flex disconnect
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Huawei P10 Main and display flex disconnect, Back Cover: passo 1, imagem 1 %32 Huawei P10 Main and display flex disconnect, Back Cover: passo 1, imagem 2 %32 Huawei P10 Main and display flex disconnect, Back Cover: passo 1, imagem 3 %32
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Main and display flex disconnect: passo 2, imagem 1 %32 Huawei P10 Main and display flex disconnect: passo 2, imagem 2 %32 Huawei P10 Main and display flex disconnect: passo 2, imagem 3 %32
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Main and display flex disconnect: passo 3, imagem 1 %32 Huawei P10 Main and display flex disconnect: passo 3, imagem 2 %32
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Main and display flex disconnect, Main and display flex disconnect: passo 4, imagem 1 %32 Huawei P10 Main and display flex disconnect, Main and display flex disconnect: passo 4, imagem 2 %32 Huawei P10 Main and display flex disconnect, Main and display flex disconnect: passo 4, imagem 3 %32
    • Remove the two Phillips #00 screws.
    • Use tweezers to remove both metal plates.
  5. Huawei P10 Main and display flex disconnect: passo 5, imagem 1 %32 Huawei P10 Main and display flex disconnect: passo 5, imagem 2 %32 Huawei P10 Main and display flex disconnect: passo 5, imagem 3 %32
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
Conclusão
Dominik Schnabelrauch
Membro desde: 11/23/16
202.558 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.718 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 64
