Ir para o conteúdo principal
Huawei P10 Lite Back cover Replacement
O que você precisa
  1. Huawei P10 Lite Back cover Replacement, Back cover: passo 1, imagem 1 %32 Huawei P10 Lite Back cover Replacement, Back cover: passo 1, imagem 2 %32 Huawei P10 Lite Back cover Replacement, Back cover: passo 1, imagem 3 %32
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Back cover Replacement: passo 2, imagem 1 %32 Huawei P10 Lite Back cover Replacement: passo 2, imagem 2 %32 Huawei P10 Lite Back cover Replacement: passo 2, imagem 3 %32
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Back cover Replacement: passo 3, imagem 1 %32 Huawei P10 Lite Back cover Replacement: passo 3, imagem 2 %32
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Back cover Replacement: passo 4, imagem 1 %32 Huawei P10 Lite Back cover Replacement: passo 4, imagem 2 %32
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
Conclusão
15 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
202.860 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.757 guias
6 comentários
Great guide, but how do I move the fingerprint sensor to the new cover?
mela ross - Responder
You need to warm the adhesive so it can be loose
Adwell Cellular -
What adhesive should I use? Thank you!
Calin GV - Responder
Nice guide! Thanks! I got a little question about the coloring of the back panel. What kind of coloring is it? Is it a coating you can take off, or is it more like a layer of paint you can scrape off? I am wondering, because I want to clear the back of my Huawei P10 lite. I hope it’s possible though.
Daan - Responder
Can you send me please back cover.
I'm from Nepal .
Md Usman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 26
Últimos 30 dias: 108
Duração total: 38,422
