Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Desligue o seu smartphone.
Remova os dois parafusos Pentalobe P2 da parte inferior.
Remova a bandeja do chip SIM.
Insira uma ferramenta de abertura de plástico entre o display e o invólucro, começando pela área inferior de seu smartphone.
Faça alavanca cuidadosamente e libere o display e suas partes para fora do invólucro.
Depois de liberar a extremidade inferior, use a ferramenta de abertura para abrir os clipes em ambos os lados.
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the two Phillips #00 screws.
Use tweezers to remove both metal plates.
Use a spudger to disconnect the interconnect, the battery and the display flex cable.
Remove the four Phillips #00 screws.
Use Tweezers to remove the metal plate.
Use a spudger to disconnect the main flex cable.
Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
Use a spudger to pry out the charging board.
Remove the charging board.
Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
Remove the loudspeaker.
Remove the antenna cable if you haven't already.
Use tweezers to remove the interconnect cable.
Use an iOpener to loosen the adhesive beneath the display. Especially take care of the upper and lower part of the display.
Insert the tip of an opening pick between the display and the midframe on the bottom of the phone, near the home button.
Slide the opening pick along the bottom edge, to cut the adhesive.
Slide the opening pick to the bottom right corner and leave it there.
Insert another opening pick under the screen on the bottom left corner.
Slide the opening pick under the screen around all edges of the phone.
Carefully pull the display assembly away from the frame.
Remove the display assembly.
23 outras pessoas executaram este guia.
4 comentários
Any advice which adhesive to use? I’ve seen a russian replacement video, it looked like the guy was using some kind of silicone.
Little late but maybe this?
I used B-7000 glue. It enables you to release the screen when a second replacement is needed.
Assuming I purchase a screen off of ebay, and replace it using this method, will the touch id still work?
