Ir para o conteúdo principal
Huawei MediaPad S7-301u Front Camera Replacement
O que você precisa
  1. Huawei MediaPad S7-301u Front Camera Replacement, Battery: passo 1, imagem 1 %32 Huawei MediaPad S7-301u Front Camera Replacement, Battery: passo 1, imagem 2 %32 Huawei MediaPad S7-301u Front Camera Replacement, Battery: passo 1, imagem 3 %32
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Front Camera Replacement: passo 2, imagem 1 %32
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Front Camera Replacement: passo 3, imagem 1 %32 Huawei MediaPad S7-301u Front Camera Replacement: passo 3, imagem 2 %32 Huawei MediaPad S7-301u Front Camera Replacement: passo 3, imagem 3 %32
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Front Camera Replacement: passo 4, imagem 1 %32 Huawei MediaPad S7-301u Front Camera Replacement: passo 4, imagem 2 %32 Huawei MediaPad S7-301u Front Camera Replacement: passo 4, imagem 3 %32
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
  5. Huawei MediaPad S7-301u Front Camera Replacement, Motherboard: passo 5, imagem 1 %32 Huawei MediaPad S7-301u Front Camera Replacement, Motherboard: passo 5, imagem 2 %32 Huawei MediaPad S7-301u Front Camera Replacement, Motherboard: passo 5, imagem 3 %32
    • Once the battery is removed, the motherboard is ready to be removed.
    • Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
    • To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
  6. Huawei MediaPad S7-301u Front Camera Replacement: passo 6, imagem 1 %32 Huawei MediaPad S7-301u Front Camera Replacement: passo 6, imagem 2 %32 Huawei MediaPad S7-301u Front Camera Replacement: passo 6, imagem 3 %32
    • Use the precision tweezers to disconnect the 7 clips from the motherboard
    • Remove the headphone input cable from the motherboard by carefully pulling on the clip.
  7. Huawei MediaPad S7-301u Front Camera Replacement: passo 7, imagem 1 %32 Huawei MediaPad S7-301u Front Camera Replacement: passo 7, imagem 2 %32
    • Unscrew the 4 screws 4mm with T5 bit from the edges or the frame of the motherboard to remove it
    • Carefully remove the motherboard from the metal frame.
    • A long thin tape will be attached to the motherboard. This tape can be pulled along with the motherboard.
  8. Huawei MediaPad S7-301u Front Camera Replacement, Front Camera: passo 8, imagem 1 %32
    • Once the battery is removed, remove the front facing camera from the socket located on the top left of the tablet.
  9. Huawei MediaPad S7-301u Front Camera Replacement: passo 9, imagem 1 %32 Huawei MediaPad S7-301u Front Camera Replacement: passo 9, imagem 2 %32
    • Gently unclip the camera from the motherboard using your fingers or a pair tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
Chenet Valmy
Membro desde: 09/26/17
213 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S11-G5, Passmore Fall 2017 Membro de USF Tampa, Team S11-G5, Passmore Fall 2017
USFT-PASSMORE-F17S11G5
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 370
