Ir para o conteúdo principal
Huawei MediaPad S7-301u Battery Replacement
O que você precisa
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: passo 1, imagem 1 %32 Huawei MediaPad S7-301u Battery Replacement, Battery: passo 1, imagem 2 %32 Huawei MediaPad S7-301u Battery Replacement, Battery: passo 1, imagem 3 %32
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: passo 2, imagem 1 %32
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: passo 3, imagem 1 %32 Huawei MediaPad S7-301u Battery Replacement: passo 3, imagem 2 %32 Huawei MediaPad S7-301u Battery Replacement: passo 3, imagem 3 %32
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: passo 4, imagem 1 %32 Huawei MediaPad S7-301u Battery Replacement: passo 4, imagem 2 %32 Huawei MediaPad S7-301u Battery Replacement: passo 4, imagem 3 %32
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
Conclusão
5 outras pessoas executaram este guia.
Miguel Lugo
Membro desde: 09/26/17
598 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S11-G5, Passmore Fall 2017 Membro de USF Tampa, Team S11-G5, Passmore Fall 2017
USFT-PASSMORE-F17S11G5
Membros da 4
Autoria de 8 guias
Um comentário
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 6,997
