Ir para o conteúdo principal
Huawei MediaPad M3 Rear Camera Replacement
O que você precisa
  1. Huawei MediaPad M3 Rear Camera Replacement, Display Assembly: passo 1, imagem 1 %32 Huawei MediaPad M3 Rear Camera Replacement, Display Assembly: passo 1, imagem 2 %32
    • Use a heat gun to heat the display. It may take up to 30 seconds.
    • Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
  2. Huawei MediaPad M3 Rear Camera Replacement: passo 2, imagem 1 %32 Huawei MediaPad M3 Rear Camera Replacement: passo 2, imagem 2 %32
    • Open the display carefully.
    • Use a Phillips #00 screwdriver to remove the two 3.0mm screws.
  3. Huawei MediaPad M3 Rear Camera Replacement: passo 3, imagem 1 %32 Huawei MediaPad M3 Rear Camera Replacement: passo 3, imagem 2 %32
    • After removing the two screws, use your hand to take out the silver metal bracket.
  4. Huawei MediaPad M3 Rear Camera Replacement: passo 4, imagem 1 %32 Huawei MediaPad M3 Rear Camera Replacement: passo 4, imagem 2 %32 Huawei MediaPad M3 Rear Camera Replacement: passo 4, imagem 3 %32
    • Use the plastic opening tool to disconnect the two ribbon cable connectors.
  5. Huawei MediaPad M3 Rear Camera Replacement: passo 5, imagem 1 %32 Huawei MediaPad M3 Rear Camera Replacement: passo 5, imagem 2 %32
    • Remove the display assembly from the device.
  6. Huawei MediaPad M3 Rear Camera Replacement, Front Camera: passo 6, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the six 3.0mm screws.
  7. Huawei MediaPad M3 Rear Camera Replacement: passo 7, imagem 1 %32
    • Use your hand to remove the silver metal bracket.
  8. Huawei MediaPad M3 Rear Camera Replacement: passo 8, imagem 1 %32 Huawei MediaPad M3 Rear Camera Replacement: passo 8, imagem 2 %32
    • Use your hand to remove the two black plastic covers.
  9. Huawei MediaPad M3 Rear Camera Replacement: passo 9, imagem 1 %32 Huawei MediaPad M3 Rear Camera Replacement: passo 9, imagem 2 %32 Huawei MediaPad M3 Rear Camera Replacement: passo 9, imagem 3 %32
    • Use a plastic opening tool to remove the front camera.
  10. Huawei MediaPad M3 Rear Camera Replacement, Rear Camera: passo 10, imagem 1 %32 Huawei MediaPad M3 Rear Camera Replacement, Rear Camera: passo 10, imagem 2 %32 Huawei MediaPad M3 Rear Camera Replacement, Rear Camera: passo 10, imagem 3 %32
    • Disconnect and remove the camera from the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 351
