Ir para o conteúdo principal
Huawei Mate 9 Rear and Front Camera Replacement
O que você precisa
  1. Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: passo 1, imagem 1 %32 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: passo 1, imagem 2 %32 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: passo 1, imagem 3 %32
    • Turn off your Huawei Mate 9 smartphone and remove the SIM card tray with a SIM card removal tool.
    • Remove the two T2 screws at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver.
  2. Huawei Mate 9 Rear and Front Camera Replacement: passo 2, imagem 1 %32 Huawei Mate 9 Rear and Front Camera Replacement: passo 2, imagem 2 %32 Huawei Mate 9 Rear and Front Camera Replacement: passo 2, imagem 3 %32
    • Using a suction cup, carefully start pulling the display assembly from the back cover.
    • Insert a pick when pulling the display assembly off the back cover, while sliding the pick along the edge of the phone to loosen the display assembly.
    • While removing the display assembly, make sure to not completely remove the back cover. This is due to the power button and fingerprint sensor cables still being connected to the motherboard.
  3. Huawei Mate 9 Rear and Front Camera Replacement: passo 3, imagem 1 %32 Huawei Mate 9 Rear and Front Camera Replacement: passo 3, imagem 2 %32
    • To protect the internal cables and components, you will need to carefully disconnect the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver.
    • Remove the metal plate with tweezers.
    • Disconnect the battery connector from the motherboard using the spudger.
  4. Huawei Mate 9 Rear and Front Camera Replacement: passo 4, imagem 1 %32 Huawei Mate 9 Rear and Front Camera Replacement: passo 4, imagem 2 %32
    • Using a spudger, disconnect the battery connector.
    • After disconnecting the battery connector, you can now completely remove the back cover.
  5. Huawei Mate 9 Rear and Front Camera Replacement: passo 5, imagem 1 %32 Huawei Mate 9 Rear and Front Camera Replacement: passo 5, imagem 2 %32 Huawei Mate 9 Rear and Front Camera Replacement: passo 5, imagem 3 %32
    • Use a Philips 000 screwdriver to remove the two 1.0 mm Philips #1 screws securing the metal plate.
    • After removing the metal plate, you can now remove and replace the rear camera from its slot.
  6. Huawei Mate 9 Rear and Front Camera Replacement: passo 6, imagem 1 %32 Huawei Mate 9 Rear and Front Camera Replacement: passo 6, imagem 2 %32
    • To remove the front-facing camera, peel off the conducting fabric from the metal shield on the display assembly.
    • Disconnect the front camera connector and remove the front-facing camera.
Conclusão
Rogelio Ramirez
Membro desde: 06/25/17
524 Reputação
Autoria de 3 guias
Equipe
UC Davis, Team S7-G8, Lore Fall 2018 Membro de UC Davis, Team S7-G8, Lore Fall 2018
UCD-LORE-F18S7G8
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 2,100
