Introdução
Use this guide to replace the display of your Huawei Mate 9 smartphone.
O que você precisa
Carefully peel off the plastic sticker that holds both cables to the battery.
Disconnect the antenna cable and remove it carefully.
Remove the five Phillips #00 screws that hold the daughter board and loudspeaker in its place.
Die kleine Schraube links oben sollte auch gelöst werden, sonst geht der Lautsprecher nich raus ;-)
Das ist natürlich richtig und wurde korrigiert!
The #00 screwes are five! One is in the bottom-left side!
That’s right! I corrected that!
Use a spudger to carefully lever up the daughterboard and remove it. Don't break the small clamps that hold down the daughter board but press them a little bit to the side to make the removal easier.
Use a spudger to remove the loudspeaker and the charging port. There is some adhesive underneath and the unit might be a little bit sticky.
Use an iOpener to loosen the adhesive beneath the display. Focus on the top and bottom area of it.
After loosening the adhesive in the upper area of your phone, use an iFlex or opening pick and insert it carefully between the mid frame and your display.
Loosen the adhesive by sliding the along the mid frame.
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it is necessary.
13 outras pessoas executaram este guia.
6 comentários
I have issue with the assembly process. Im adding 3m adhesive tape that I received with replacement screen, and everything looks fine. But after inserting phone into aluminium back the screen pop out int the middle of frame, delaminating and showing backlight of lcd. The adhesive just not hold it enough..
The iFlex isn’t listed in the tools.
Check, now it is listed. Thanks for the note.
it’s almost impossible to remove the battery without damaging it!
My advice to you is to buy the LCD screen with the battery included.
Removal of battery absolutely / highly recomended, Display parts group needs to be heated to remove adhesive, and believe me - there is lots of it, either by i-opener or other means.
Also yes, battery can't be removed without damage, to much adhesive on to much contact area of battery.
