Introdução
Use this guide to replace the loudspeaker in your Huawei Mate 8.
  1. Switch off your phone and remove the SIM card tray. Switch off your phone and remove the SIM card tray.
    • Switch off your phone and remove the SIM card tray.
  2. Remove the Torx T2 screws from the bottom of the phone
    • Remove the Torx T2 screws from the bottom of the phone
  3. Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel. Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Use an opening pick to fully separate the clips, releasing the phone. Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover. Open the phone like a book from the SIM tray side.
    • Use an opening pick to fully separate the clips, releasing the phone.
      • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Remove the liquid indicator sticker. Remove the Phillips #00 screw that holds down the metal shield. The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  7. Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables. Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables. Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  8. Remove the Phillips #00 screw that holds down the interconnect cable bracket.
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  9. Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket. Remove the bracket.
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  10. Use a spudger to disconnect the interconnect cable.
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  11. Remove the two Phillips #00 screws. Use the flat end a spudger to disconnect the loudspeaker flex connector. Use the pointy end of a spudger to pry out the daughterboard.
    • Remove the two Phillips #00 screws.
    • Use the flat end a spudger to disconnect the loudspeaker flex connector.
    • Use the pointy end of a spudger to pry out the daughterboard.
    • Remove the daughterboard.
  12. Remove the two Phillips #00 screws. Use the tip of a spudger on the left side of the loudspeaker to pry it out. Remove the loudspeaker.
    • Use the tip of a spudger on the left side of the loudspeaker to pry it out.
    • Remove the loudspeaker.
Conclusão
2 outras pessoas concluíram este guia.
Theo Mat
9.877 reputação
14 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 18
Todo: 318
