Ir para o conteúdo principal
Huawei Mate 10 Pro Back Cover Replacement
O que você precisa
  1. Huawei Mate 10 Pro Back Cover Replacement, SIM Card Tray: passo 1, imagem 1 %32 Huawei Mate 10 Pro Back Cover Replacement, SIM Card Tray: passo 1, imagem 2 %32
    • Insert a SIM opening tool in the hole on the left side and push it in.
    • Remove the SIM card tray.
  2. Huawei Mate 10 Pro Back Cover Replacement, Back Cover: passo 2, imagem 1 %32
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  3. Huawei Mate 10 Pro Back Cover Replacement: passo 3, imagem 1 %32 Huawei Mate 10 Pro Back Cover Replacement: passo 3, imagem 2 %32 Huawei Mate 10 Pro Back Cover Replacement: passo 3, imagem 3 %32
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  4. Huawei Mate 10 Pro Back Cover Replacement: passo 4, imagem 1 %32 Huawei Mate 10 Pro Back Cover Replacement: passo 4, imagem 2 %32
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  5. Huawei Mate 10 Pro Back Cover Replacement: passo 5, imagem 1 %32 Huawei Mate 10 Pro Back Cover Replacement: passo 5, imagem 2 %32
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
Conclusão
11 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
203.329 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
2 comentários
Where can I buy the back part of the phone. Email me at brownpridebandit@gmail.com
Luis Liberato - Responder
Thanks for good work you do
amoudi Guide - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 69
Duração total: 16,183
